brakes on S2
Old May 28, 2005 | 12:44 PM
Daz-rst's Avatar
Daz-rst
Default brakes on S2
hi want bigger and better brakes on me S2. which ones are best i know st170 ones will fit but i heard either the saph cossie 2wd or 4wd brakes will fit i cant remember which. any help as to which ones will?? how hard are they to fit??? and can ya still buy saph cossie brakes from ford???
Old May 28, 2005 | 02:52 PM
tonyturbo's Avatar
tonyturbo
you want 2wd discs and 4wd calipers and they'l bolt straight on.
tonyturbo's Avatar
tonyturbo
Old May 28, 2005 | 03:17 PM
Daz-rst's Avatar
Daz-rst
Default cheers bud
cheers matey
they just fit under 15" wheels dont they??? i heard u had to widen the hole for the caliper bolt??? if they bolt straight would be awesome.
can u still get em from fords or is there websites where i can get em from???
cheers
daz
Old May 29, 2005 | 10:58 PM
S1MAN's Avatar
S1MAN
Just need to use a 1mm spacer between the caliper brackets/strut mounts to centralise the calipers on the disc's. No need to do any drilling.
Try www.fordpartsuk.com for your calipers if you want to use new.
Colin.
muzzman1
Sep 30, 2015 08:59 PM
Sp3no
Sep 27, 2015 07:23 PM
