Engine Dies momentarily....intermittent...Any idea's???
Old May 15, 2005 | 06:17 AM
CosRush's Avatar
CosRush
Default Engine Dies momentarily....intermittent...Any idea's???
Occassionally when pulling out from a junction, my engine dies.
If your quick you can dip the clutch, and rev it again, but usually it'll die again. Then all of a sudden it'll go backto normal.....
Ive had lots of sensors changed and it has been setup and running perfectly.
The only sensor i haven't changed is the ignition Amp.
Before i go and buy one, just wondered if anybody had any idea's of what to check.
Engine is a stage 3 Sapph 4x4 Red Top, 803's, T34 running 24psi held.
Old May 15, 2005 | 10:47 AM
Stu @ M Developments's Avatar
PassionFords Creator
Ignition amp is actually quite likely.
As a clue, if it is this, the rev counter will just drop like a stone as though you turned teh ignition off when the fault occurs.
Old May 15, 2005 | 08:11 PM
CosRush's Avatar
CosRush
Thanks Stu,
I'll keep an eye on it the next time it does it...
Cheers , Hopefully that'll be all it is....
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
Ben26
Ford Focus Diesel
Aug 18, 2015 03:42 PM
JoeyBoyden
14
Aug 15, 2015 09:51 PM
st220kyle
Ford Mondeo Including ST
Aug 6, 2015 09:17 PM
