fia battery master switch
Old May 8, 2005 | 07:50 PM
no grip's Avatar
no grip
Default fia battery master switch
does anybody know how to wire up an fia battery master switch? i cant work out where the 4 small contacts connect to.
Old May 9, 2005 | 09:03 PM
Paul T's Avatar
Paul T
The 4 contacts are from 2 additional contacts, call them A & B.
With the main switch on, contact A is open and B is closed. Turn the switch off and A closes and B opens.
You wire your ignition feed through B so it kills the engine.
Contact A is used to ground the electrics via a large resistor which should have been supplied with the switch. This gives the output of the alternator a route to earth when you disconnect the battery with the engine running, or you can damage it.
But these small auxiliary contacts frequently fail!
Old May 9, 2005 | 09:23 PM
no grip's Avatar
no grip
cheers - that actually makes sense - i need to get a resistor though
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
cossie330
Sep 27, 2015 04:13 PM
