RE...HOT AND BOTHERED.......
Old May 27, 2004 | 07:17 PM
cossie carl's Avatar
cossie carl
Default RE...HOT AND BOTHERED.......
those of you who have read my previuos thread know all about it.....
car is going into garage tomorrow afternoon...... one thing i sussed 2nite
is...... it ONLY pressurises and bubbles when engine is turned off...
if i restart engine, it stops pressurising and bubbling.... so......
pressurising prob is only apparent when i turn off engine....
does this help with a diagnosis ????
this still point to head gasket ???? i,ve changed thermostat, and bled system, and swore like fook
need an ace spanner man for this one.....
,,,,um..... martin?????
cheeRS
CARL........
SAFF COSSIE 4X4 STANDARD APART FROM ZORST...1991
Old May 28, 2004 | 07:09 AM
cossie carl
anyone ????
Old May 28, 2004 | 07:16 AM
Azrael's Avatar
Azrael
When you turn it off when hot it has to bubble as coolant boils in the turbo....
But I don't know if you mean that....
Old May 28, 2004 | 08:15 AM
cossie carl
SO, THIS SHOULD HAPPEN ???
I,M BEING TOO PARANOID ??
IT IS A VIOLENT BUBBLING AND PRESSURISING , THO ??
SOON AS I START ENGINE , IT STOPS ?????
SO, IS CAR OK ??
GET IT CHECKED ??
CARL....
TEMP GAUGE WHILE DRIVING NEVER GOES ABOVE THE "R" ON NORMAL
Old May 28, 2004 | 08:29 AM
Azrael's Avatar
Azrael
Dunno :-/ Every turbo car will boil when you stop the engine but how much is hard to judge from description. If you are not loosing coolant it's probably normal.
Old May 28, 2004 | 09:15 AM
cossie carl
AZRAEL.....
top man, just dropped car off and garage man said exactly same as you.....
so, gonna have a top notch service for my money instead of
headgasket change......
plugs/leads/dizzy cap/rotor arm plus a few small jobs
cheeRS m8te
CARL........
Old May 28, 2004 | 09:19 AM
Azrael's Avatar
Azrael
Sometimes I happen to know what I'm talking about...sometimes
Fitness / Weight Training Discussions
Mar 26, 2006 05:28 PM
