drive shaft circlip
Old Apr 30, 2020 | 02:01 PM
Old Geezer's Avatar
Old Geezer
Default drive shaft circlip
Hi Folks,
Does anybody know whether it is necessary to put the circlip back in on the RH drive shaft located in the front diff housing on the 4 x 4 Saphire when you reassemble. I cant see that it does anything and it prevents you from replacing the diff oil pan cover with sealant etc before you put the engine back in the car. Much easier to do it with the engine out! Cheers.
Old May 2, 2020 | 08:32 PM
Caddyshack's Avatar
Caddyshack
10 Year Member
I think a lot are left out. It was when I opened my front diff and at the time many People said it is likely not to be there.
Old May 2, 2020 | 09:46 PM
christos's Avatar
christos
10 Year Member
Most people don't use circlip. It's a lot easier to remove driveshaft..
Old May 5, 2020 | 10:34 AM
Old Geezer's Avatar
Old Geezer
Thanks guys...I will leave it out!
COLEYST200
Mar 10, 2017 06:57 AM
AlexD
Ford Escort RS Cosworth
Dec 14, 2008 06:38 AM
Mr C
Jan 11, 2007 08:01 PM
SPADGE
24
Apr 20, 2005 08:21 AM
Phil
Dec 22, 2004 12:19 PM
