88 xr3i
Old Apr 20, 2020 | 10:14 AM
Carl john's Avatar
Carl john
Default 88 xr3i
I have just rebuild the top end with piper cam and I now have a misfire at 4000rpm any thoughts?
Old Apr 20, 2020 | 11:03 AM
haz87's Avatar
haz87
What did you do as part of the rebuild?
Is it new cam? Was it dialled in properly?
Messed with the ignition timing and/or set it correctly on rebuild?
Too many variables - some info of what you've done will narrow it down.
Old Apr 20, 2020 | 12:44 PM
Carl john's Avatar
Carl john
It's had a piper cam kit new can, lifters,springs and stem oil seals. Timing is spot on runs sweet until late I get 4g thenot it seems to running on 3 cylinders
Old Apr 20, 2020 | 12:48 PM
Carl john's Avatar
Carl john
Also put a new 4 branch manifold, new oil and air filters
Old Apr 20, 2020 | 01:32 PM
haz87's Avatar
haz87
"Timing is spot on" - assume you mean cam timing and it was dialled in then? (although using the "dot" would be close enough on a mild cam/standard skim head)
Did you run the cam in properly?
Have you checked and confirmed ignition timing since the rebuild?
Chances are its going to be one of two things:
-Ignition timing (12btdc on Premium (VPower) fuel)
-Cams wiped a lobe because... well Piper cam
Kelv
Jul 24, 2007 12:23 PM
haz87
22
Mar 21, 2006 09:40 PM
xr dave
Jan 6, 2006 06:06 PM
