yb na wont rev
Old Apr 13, 2018 | 06:25 AM
bobby sehmi's Avatar
bobby sehmi
Default yb na wont rev
my yb na wont rev freely over 6,000 rpm.
specs of the engine;
1. cosworth 9 bolt crank, cosworth turbo rods, acl duraglide main and con bearings
2. accralite forged pistons 12:1. cut to comp ratio of 10.5 : 1 for local fuel
3. twin weber 48's. ported to some extent. 42 venturi, 145 main, f16 tubes 210 correctors
4. newman cams 300/440, solid lifters
the engine pulls well from 3,500 rpm to 6,000 but then tails out quickly after 6,200. i expected the engine to rev up to 7,500 easily, but it just wont go.
any ideas why this is happening?
Old Apr 13, 2018 | 02:34 PM
Caddyshack's Avatar
Caddyshack
10 Year Member
I expect it is the Webber’s, ideally swap to throttle bodies and get someone who knows their stuff to map it. If not get someone who knows Webber’s to set them up and check timing etc.
Old Apr 13, 2018 | 04:17 PM
GVK.'s Avatar
GVK.
Webers should be ok at that rpm, especially 48s!!
Old Apr 13, 2018 | 04:24 PM
Turbosystems's Avatar
Turbosystems
Super Moderator
What valve spring have you fitted It could well be valve float
Old Apr 13, 2018 | 04:26 PM
Caddyshack's Avatar
Caddyshack
10 Year Member
Totally, but only if you can get them set up right. The ones I had on a pinto were terrible, in my experience Webber’s are flat spots intermingled with running rich.
Old May 8, 2018 | 09:48 PM
pete241's Avatar
pete241
Check you cam timing,iv found that if inlet cam is out on my Yb to advanced will choke the engine,worth a look in,Carbs or other would run lean or rich would thought
Osborne0121
Feb 19, 2014 07:43 PM
mercmark
Sep 24, 2008 04:36 AM
BeanFiesta
Feb 15, 2006 04:32 PM
Mar 23, 2004 09:55 AM
