Zetec silvertop coil
Old Dec 20, 2016 | 06:58 PM
f40cab's Avatar
f40cab
Default Zetec silvertop coil
Hi people building zetec turbo. Anyone had trouble or no of any trouble with the coil packs. And is there anything else to use
Old Dec 21, 2016 | 01:49 PM
big_wasa's Avatar
big_wasa
Depends on power and what ecu your using.
The Black top coil fits the bracket but you will need new plug leads. It's used on the focus rs.
Old Dec 21, 2016 | 02:15 PM
f40cab's Avatar
f40cab
OK I'm going omex 600 and 350bhp. Been told the coil packs are crap and they fail never heard anything before so just checking.
haz87's Avatar
haz87
Standard coil is fine for the majority of applications out there
Old Dec 21, 2016 | 02:18 PM
haz87's Avatar
haz87
Cheap nasty aftermarket ones arent great. Blacktop coilpacks have a FAR higher failure rate IMO. Think ive changed 3 silvertops in my time (one 20+yr OE, the others cheap eurocarpart specials), lost count of blacktop types replaced
Old Dec 21, 2016 | 02:28 PM
f40cab's Avatar
f40cab
OK thanks for advice. I've got new set of magnecor 8.5 leads. And just been told the zetec packs are crap and fail and should use coil on plug type. Maybe future modification see how standard ones go. Thanks for everyone's help.
Old Dec 21, 2016 | 07:16 PM
big_wasa's Avatar
big_wasa
I've replaced a couple of silvertop coils but not a Blacktop coil. You don't have to many options on an omex 600 other than wasted spark.
I would buy new genuine ford coil, plugs and leads and they should be fine.There is many an Rs running that.
