turbo play
Old Sep 11, 2016 | 12:18 PM
rsguy's Avatar
rsguy
Default turbo play
quick question guys about a used turbo i bought
seller said turbo ran perfectly There is slight play in the shaft side to side and up and down but none in and out. Got told the side to side movement is from the turbo being A journal bearing type.
i have also noticed a slight honeing mark on the compressor housing under compressor wheel. ( lighter grey in colour to rest of houseing ) I’ve also been told thats normal caused due to starting the car from cold so no pressurised oil to centre the bearing.
im not sure how much all this is true as im no expert on turbos so just wanted to ask before i either keep it or send this back to seller.
i have attached a photo
and video link below of me moving the compressor wheel up/down and left/right.
Old Sep 11, 2016 | 10:48 PM
Mad_Mat's Avatar
Mad_Mat
New Owner
Far to much movement bearings are shot imo. Any movement should be minimal.
Old Sep 11, 2016 | 10:50 PM
Mad_Mat's Avatar
Mad_Mat
New Owner
I am no expert. Just a home bodger but definitely that is not good.
Old Sep 12, 2016 | 04:11 PM
rsguy's Avatar
rsguy
ok thanks guys.
would you say looking at the video theres more than 1mm of play ?
reason i ask i spoke with guy from turbo technics and he said there should not be any more than 1mm play side to side or any direction.
thing is my old turbo has play so i only bought this used as seller said the turbos good and theres normal min play on this turbo. but turbo technics suggest it sounds worn.
i might as well get my old turbo refubed. so i dont see the point in keeping this. as sounds like i have 2 worn turbos now instead of one.
Old Sep 13, 2016 | 02:43 AM
Mad_Mat's Avatar
Mad_Mat
New Owner
Yes it looks alot more than 1mm to me. If the bearings have enough wear that the compressor wheel is able to touch the housing they are totally shagged imo.
I am surprised no one else has chipped in with an opinion
Old Sep 18, 2016 | 10:02 AM
stevieturbo's Avatar
stevieturbo
C**t
There are no signs of it touching the housing etc, it looks perfectly fine.
Journal bearing turbos will always have free play in them
Mark RS
Dec 3, 2016 05:51 PM
49
Aug 26, 2016 11:53 AM
graham c
14
Aug 17, 2016 12:35 PM
5hane
Aug 17, 2016 11:18 AM
truescot69
Aug 15, 2016 08:25 PM
