N/A ZVH engine???
Old Jun 13, 2016 | 08:18 PM
matty325's Avatar
matty325
Default N/A ZVH engine???
has anyone ever built one? thinking of doing one for my mk3 xr3i. the reason being i want to keep it looking original under the bonnet as ford intended.i know full zetec would be easier and give more power bla bla but i just want maybe an extra 20-30 bhp with some cvh head work/cam and 2.0 bottom end .would the mfi be up to fueling one?
Old Jun 14, 2016 | 04:51 AM
haz87's Avatar
haz87
I built/use one (tho 1.8 bottom end) following me absolutely obliterating my CVH and needing to build something quick. Mines all on Mfi, its easily capable
Old Jun 14, 2016 | 05:31 AM
matty325's Avatar
matty325
thanks mate your just the type of person i was hoping would reply ,was there much power gain over the cvh ,did you do any head work? was compression ratio an issue? ,cheers matty
Old Jun 14, 2016 | 08:31 AM
haz87's Avatar
haz87
I skimmed the head quite a bit to bring comp ratio up. It was a power drop for me as my CVH (n/a) had absolutely the best of the best at the time. But its a daily driver and the ZVH suits traffic and general cruising far better.
I imagine on a standard CVH, a zvh would feel far better even on a standard port skimmed head and decent cam purely from the torque benifit
Old Jun 14, 2016 | 11:37 AM
matty325's Avatar
matty325
Any idea what compression ratio it has?how much did u skim off .do you think it can be done with the two litre as well
Old Jun 14, 2016 | 02:46 PM
haz87's Avatar
haz87
2lt is perfectly do-able however there is extra welding required on the mating surface (well documented if you google).
Skimmed 1.5mm or maybe 2 (it was a good 3yrs ago) bought comp upto around 11:1
However this leaves very little margin for error on the head going forward.. as in dont warp it as you have little meat to re-skim
Old Jun 14, 2016 | 03:28 PM
matty325's Avatar
matty325
great thanks ,was decking the block an option do you think to save the the head a little?
Old Jun 14, 2016 | 03:57 PM
haz87's Avatar
haz87
Quite possible. Not a route i looked into tbh
admanrs
Mar 20, 2017 07:21 PM
Chopshop85
Aug 26, 2016 12:45 PM
Shaunc
Escort Range
May 8, 2016 08:15 PM
daren5675
Mar 27, 2016 10:57 AM
428cj
Mar 19, 2016 03:37 PM
