sierra rear beam HELP
Old Feb 21, 2016 | 07:25 AM
modifyitmike's Avatar
modifyitmike
Default sierra rear beam HELP
Hi all.
this one may be simple for some people,
sierra rear beam. ( just the horseshoe shape steelwork ) are they the same for all models.
i know early had drum , while later had discs, and lsd and non lsd diffs, 7 and 7.5 inch diffs but what i need to know is the beam the same for all models.
eg.
if i had a non lsd drum setup. would a lsd discs setup just bolt together.
thanks all
mike
Old Feb 21, 2016 | 09:17 AM
martysmartie's Avatar
martysmartie
Generally they are 7", the exception being the 2WD Cosworth and another model which have 7.5".
So, as long as it matches the diff you have I don't see why not, the arms can be changed to suit disc/drum.
Martin
Old Feb 21, 2016 | 12:17 PM
modifyitmike
thanks martysmartie.
what im trying to find out is. if the drum arms are the same as dics arms, other than bolt on the drum or disc arrangment. and would a 7 inch diff bolt up the same as 7,5 . hope this explains it.
mike
Old Feb 22, 2016 | 08:26 PM
martysmartie
It would with some spacers.
Martin
mk1 rst
Alloy wheels and ICE for sale
May 8, 2016 02:08 PM
rossimk2
Mar 6, 2016 10:32 AM
markk
Feb 19, 2016 02:55 PM
c14rks
Feb 18, 2016 08:41 PM
mk1 rst
Feb 15, 2016 11:53 AM
