Custom inlet manifold urgent help!!!
Old Jun 10, 2015 | 10:27 AM
george the greek's Avatar
george the greek
Exclamation Custom inlet manifold urgent help!!!
Hello, I had a custom inlet manifold made for a fiesta rs turbo engine with a Dellorto throttle body, the problem that I have is that the butterfly on the Dellorto turns the opposite way than the standard efi item which means my TPS is useless. What other throttle position sensor can I use? (the engine is on OFAB). Any body had a similar problem? How did you come around?
Thanx George
Old Jun 10, 2015 | 10:42 AM
Caddyshack's Avatar
Caddyshack
Thanx George
Can you stick up a pick of what you have?
You may need to speak to Dave Walker at Emerald as he can solve a few things like that
Old Jun 10, 2015 | 11:08 AM
haz87's Avatar
haz87
Just reverse the wiring
Old Jun 10, 2015 | 03:15 PM
george the greek
As you can see in the image below there is an arrow pointing the direction from closed to open, the potentiometer is actually one way and it wont go the other way so reversing the wires is pointless I think. What I need is TPS that turns the opposite way and also be in the Ohm range of the original I guess.......
Old Jun 10, 2015 | 03:17 PM
george the greek
Old Jun 10, 2015 | 05:44 PM
Caddyshack's Avatar
Caddyshack
Thanks for the pic. I assume you cannot take out the spindle and adjust the start point, in theory you need the butterfly out and flip the start point or put the tps upside down?
Old Jun 10, 2015 | 05:49 PM
george the greek
Unfortunately the spindle cannot be adjusted
Caddyshack's Avatar
Caddyshack
A complicated way would be a gear on the output shaft that the tps would normally sit on and an equal gear meshed running the tps, this would reverse the moment / motion. But that would take a bit of fabrication. You could use Lego cogs from Lego technic mounted on some metal or even mocked up all on Lego and glue the whole thing together and maybe put metal over top. The Lego models they use at legoland are often just superglued together.
A watchmaker or gunsmith could copy it in brass I suspect.
Old Jun 10, 2015 | 05:51 PM
Caddyshack's Avatar
Caddyshack
I bet if you can get the shaft out and turn it through 180 degrees it should work for you...it is hard without having it in my hands to play with.
Dave walkers website, I know he could solve it http://www.emeraldm3d.com/about-us
Old Jun 10, 2015 | 05:53 PM
george the greek
I bet that there is a simpler way lol
Old Jun 10, 2015 | 05:57 PM
Caddyshack's Avatar
Caddyshack
Just been googling dellorto and it seems they use the Webber alpha tps. I will keep reading a bit more and report back
Old Jun 10, 2015 | 05:59 PM
Caddyshack's Avatar
Caddyshack
This looks interesting, might be worth calling them?
http://www.dellorto.co.uk/shop/dhla-...dhla-40-45-48/
Old Jun 10, 2015 | 06:01 PM
Caddyshack's Avatar
Caddyshack
Ok, another idea. ...just weld another shaft on top at the correct position, surely you can cut the half moon off, flip it round 180 and re attach?
Old Jun 10, 2015 | 06:02 PM
Caddyshack's Avatar
Caddyshack
The bottom pic looks like you have a tiled engine bay lol
Old Jun 10, 2015 | 06:14 PM
george the greek
Tiles are much easier to clean !!
wowk
Mar 30, 2021 07:49 PM
caprixpack
Sep 25, 2015 07:53 PM
