Adding a vacuum for brake servo
Old Apr 12, 2015 | 07:40 AM
Caddyshack's Avatar
Caddyshack
Default Adding a vacuum for brake servo
I need to add a vacuum for my brake servo and wondered where the best place is to add it and what is the best way of going about it?
I have found a one way valve to stop any positive boost going in to the servo.
The servo is off a 205 gti (my car is a cossie engined pug) and I have added a 405 master cylinder as they are bigger. https://passionford.com/forum/restor...ng-gear-9.html
Old Apr 12, 2015 | 10:00 AM
MK MOTORSPORT's Avatar
MK MOTORSPORT
best place is plenum cover ,but better still fit the cossy pedal box pump assembley
Old Apr 12, 2015 | 04:23 PM
Caddyshack's Avatar
Caddyshack
I actually have a cossie master cylinder mated to a pug pedal box from the original conversion but I have binned the abs although I believe you can still fire up the pressure accumulator so I could have a go at wiring that in to come on with the ignition although never liked the noise they make at start up and seemed to put a big battery drain in.
Thanks for the advice re the plenum, I wondered if there were better or worse areas in the plenum but I guess adding it where the other sensor holes are should be fine?
Old Apr 12, 2015 | 07:41 PM
slider's Avatar
slider
http://www.burtonpower.com/parts-by-...-yb-sc501.html
this is what you need m8, theres a blank fitted to the inlet manifild near the temp switch, screw this is there and job done, its what om using on my mk1 escort yb
Old Apr 12, 2015 | 08:09 PM
Caddyshack's Avatar
Caddyshack
Thank you, that is perfect, I have ordered one.
muzzman1
Sep 30, 2015 08:59 PM
Sp3no
Sep 27, 2015 07:23 PM
