ST170 Engine into a mk4 escort estate
Old Dec 15, 2014 | 07:19 PM
mondeomark's Avatar
mondeomark
From: Newcastle-under-Lyme, Stoke-on-Trent, Staffordshire
Default ST170 Engine into a mk4 escort estate
Hi everyone I have a mk4 escort estate which is currently running a 1.6 cvh out of a xr2. I've been offered the engine, gearbox, loom and ecu with the immobiliser chip from a 2002 ST170. What I want to know is how easy the conversion is and what have other people done with regards to the wiring and ecu as much info would be much appreciated. Thanks mark
Old Dec 15, 2014 | 08:57 PM
studabear's Avatar
studabear
For mounting the gearbox and engine your gonna need custom mounts for gearbox, modified cvh engine mounting. Servo and gearbox will conflict and need work, then there is a hydraulic clutch conversion to think about, aswell as custom driveshafts and possibly other bits before even thinking about wiring.
Old Dec 16, 2014 | 06:03 AM
mondeomark's Avatar
mondeomark
Thanks for that mate I'm not going to use the six speed box going to use a rs Turbo box or a diesel box so dropping the engine in should be quite straight forward.
Old Dec 16, 2014 | 09:28 AM
studabear's Avatar
studabear
Yeah enlarge cvh turbo flywheel bolt holes and the sump will need mods, have a look at karlos G's zetec turbo guide, that will steer you in the right direction. I run a st170 based zetec turbo.
Old Dec 16, 2014 | 05:31 PM
CosworthGuy's Avatar
CosworthGuy
3dr Cosworth owner
ADE The fast ford snapper did this exact conversion in his mk4 escort estate. The mag featured it and Im sure he did a how to on here too
Old Dec 16, 2014 | 06:02 PM
mondeomark's Avatar
mondeomark
Any idea where the how too is mate?
Old Dec 19, 2014 | 04:07 PM
mondeomark's Avatar
mondeomark
Any more info chaps or a list of parts I will need??
Old Dec 21, 2014 | 11:28 AM
mondeomark's Avatar
mondeomark
I could do with a list of parts I need can someone help me???
Vincereese
Jun 1, 2023 09:14 AM
Vincereese
Aug 16, 2015 06:38 PM
A.t.p
Aug 15, 2015 11:37 AM
track.focus'd
Aug 12, 2015 05:53 PM
3i Jim
Was It You?
Aug 1, 2015 06:33 PM
