Removing Turbo from 2wd,HELP.
Old May 10, 2004 | 09:22 PM
simonc's Avatar
simonc
Default Removing Turbo from 2wd,HELP.
Have removed 3 of the nuts from the exh manifold where it bolts to the exhaust housing on the turbo but i'm not having a lot of luck with the last nut as i can't get a ring spanner on it or a socket & my open ended spanner is starting to round the nut off ! Any ideas please.
Cheers Simon.
Old May 11, 2004 | 11:45 AM
simonc's Avatar
simonc
Removed seized nut now. Trying to remove the exhaust housing & turbo from where it bolts to the manifold with 4 nuts but their doesn't seem to be enough room to remove it as the bracket for the turbo damper is tight against the bit that pokes out on the head for the turbo damper, is this the wrong way to remove it ? Help !
Cheers Simon.
Old May 11, 2004 | 12:13 PM
Toe Knee's Avatar
Toe Knee
Ive always undone the 4 bolts that split the manifold in 2 when ive taken my turbo off........................
Old May 11, 2004 | 03:27 PM
simonc's Avatar
simonc
Thanks Toe knee i'll try that then,though mine has 4 funny nuts holding that part together,there small nuts with sharp edges weird things !
Cheers Simon.
Old May 11, 2004 | 04:13 PM
simonc's Avatar
simonc
Thanks Toe Knee, turbo now removed
Cheers Simon.
Matt Baxter
Sep 16, 2015 08:30 PM
EoinXR3
Sep 7, 2015 05:44 AM
kevin36
Aug 14, 2015 08:36 AM
lockie
Jul 31, 2015 10:03 PM
