Ford Focus - Safing Sensor?
Old May 11, 2014 | 10:06 AM
paulsheerin's Avatar
paulsheerin
Default Ford Focus - Safing Sensor?
Hi Guys,
The airbag light on my Focus has been giving me the following codes;
23- Safing Sensor Circuit Input Feed/Return Circuit Open (does this once)
22- Safing Sensor Output Shorted to Battery Voltage (keeps flashing this)
Anybody any ideas on how to trace this issue or where the safing sensor is located? I have a donor Focus sitting there with no airbag issues that I can pull most parts from.
Paul
Old May 11, 2014 | 11:49 AM
mark826's Avatar
mark826
Air Bag Control Module
The air bag control module governs the operation of the whole system, including the diagnostic element. It contains two frontal impact micro machine sensors; a crash sensor and a safing sensor. These two sensors are connected in series and if they both sense a deceleration in excess of a predetermined limit, the air bag control module will deploy the air bag module(s).
Info taken from Ford etis
Old May 11, 2014 | 05:29 PM
paulsheerin
Hi, thanks for that.
So does that mean that the safing sensors are contained within the control module?
Does ETIS list if they need to be reset or will I need to try get a matching replacement from an uncrashed car from a breakers?
Old May 11, 2014 | 10:01 PM
mark826's Avatar
mark826
I don't think they can be reset. And I'm sure a new module has to be programmed to the vehicle otherwise it will throw up a code for mis matched modules. As for the flash codes these tend to indicate a general area of where the fault is. It would be better to retrieve an actual fault code before throwing parts at it.
Old May 12, 2014 | 07:23 PM
paulsheerin
Cheers for that.
I'll have to chase up someone to plug it in for an accurate diagnostic.
Ford Focus RS Parts for Sale.
Aug 18, 2015 05:25 PM
taylora1409
Aug 12, 2015 12:06 PM
