mk5 hazards not working
Old Mar 4, 2014 | 11:05 PM
mball83's Avatar
mball83
Default mk5 hazards not working
hi
ive got a mk 5 fiesta 1.25 16 v on 51 plate and i cant get hazards working all indicators work fine its just wen i press the switch it does nothing but if i hold it half way down it works and also my reverse light isn't working too checked bulbs but all good need these sorting so i can put through mot
thanks for your help if any 1 can
Old Mar 4, 2014 | 11:26 PM
GVK.'s Avatar
GVK.
Probably just got dust in the hazard switch, work it up and down really fast a few times usually cures it. Blow it out with compressed air.
Reverse lights aren't part of MOT but you need to see if any power and earth at the bulb holder, check the fuses. Also on the front of the gearbox you have the reverse switch, disconnect it and get a paper clip, with the ignition on, put the paper clip in the connector to bridge the terminals, the reverse lights should come on, if they do, it's the switch fault.
Don't let the paper clip touch any metal parts of the car when testing it, as will blow the fuse
Old Mar 4, 2014 | 11:43 PM
mball83's Avatar
mball83
will give it a go in morning other things got to do is welding bit near driver side seat and passenger door hinge then central locking other than them it should pass mot i hope
Chas
Sep 21, 2015 08:57 PM
RockinRein
Aug 19, 2015 07:08 PM
Seanyfarrell
Aug 14, 2015 11:37 PM
turbobill
Aug 1, 2015 08:55 PM
