MK3 Escort Brake Upgrade
Old Sep 11, 2013 | 08:45 PM
nicodinho's Avatar
Winters over time to work
Default MK3 Escort Brake Upgrade
Want to beef up the brakes on my 1.1 - soon to be 1.6 or 2.0l - mk3 escort.
Would like to know the best easiest and most readily available front disc and caliper upgrade.
I have seen the guys putting 2.0l Turbos in track cars using cossie sets but I really dont think I need that. But your help and advice as always is appreciated
Old Sep 11, 2013 | 08:54 PM
studabear's Avatar
studabear
I've got a set of s2 rst calipers you can have for free if you want, you can use rst 263mm discs with them and they will bolt straight on.
Old Sep 11, 2013 | 09:08 PM
nicodinho's Avatar
Really? Thats Amazing! Thank you! Have you got Paypal so I can cover postage?
Also where is best place topick up the discs?
Old Sep 11, 2013 | 09:27 PM
studabear's Avatar
studabear
ebay or your local motor factors, like unipart or eurocar parts etc.
I will dig them out in my garage, check they are ok then we can look at getting them upto you.
Old Sep 11, 2013 | 09:40 PM
nicodinho's Avatar
Nice one. Let me know. Cheers
Old Sep 11, 2013 | 10:38 PM
7sean7m7's Avatar
7sean7m7
I put some S2 RST brakes on my mk3, such a difference!
Old Sep 12, 2013 | 04:36 AM
rsmark86's Avatar
rsmark86
stu collins has some s2 rst calipers with ebc greenstuff pads and drilled and grooved discs for sale.........
also a bigger servo will make a world of difference
alot of people are going down the route of fitting a mondeo unit
Old Sep 12, 2013 | 09:11 AM
Twizz's Avatar
Twizz
Out of many, we are one.
I've got a set of ST170 (300mm discs) along with Mondeo Mk3 calipers on the estate - problem is trying to find wheels that fit over the calipers (16's generally do, some 15's do and some people shave a little off the edge of the caliper allowing them to fit 15's)
My friend has the mondy/st170 set up on his MK4 Fiesta too.
Vincereese
Jun 1, 2023 09:14 AM
SmudgerByName
52
Jul 28, 2016 06:14 PM
FlashRS
Sep 14, 2015 12:36 PM
Vincereese
Aug 18, 2015 03:57 PM
Vincereese
Aug 16, 2015 06:38 PM
