Focus st misfire?
Old Jun 21, 2013 | 08:12 PM
locum8's Avatar
locum8
Default Focus st misfire?
Hi guys, I have been having an issue with my focus st 2009.
When I drive the car fast ie over 5000rpm then the engine management light flashes and the car starts to misfire. But if I pull over and switch the engine off and start it again the problem is gone. I have also check fault codes with bluefin which says no dtc found. It doesn't do it all the time only twice this year. I fitted rs plug thinking it was spark blowout but still no change. Ps the car is at stage 3.
Thanks!
Old Jun 21, 2013 | 09:24 PM
studabear's Avatar
studabear
I would possibly start by having it checked for codes with another tool, incase the bluefin only does eobd codes.
Old Jun 28, 2013 | 03:18 PM
davidg5506's Avatar
davidg5506
As above, also coil packs, is ur water and oil ok what is ur idle like ?
Sp3no
Sep 27, 2015 07:23 PM
Marv888
Sep 26, 2015 03:44 PM
Tank Mike
Sep 26, 2015 08:07 AM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
