vernier pulleys
Old May 22, 2013 | 07:22 PM
carp man's Avatar
carp man
Default vernier pulleys
my 2wd saff has vernier pullys that are adjusted inlet full one way and exhaust full the other i know this is not at all in technical terms but it just seems wrong i have a receipt for bd14 cams that i assume are fitted to the engine would this be why they are like this and also it runs quite lumpy at idle and has a bit of a flat spot when you stab the throttle its hard to explain but its just not right its got new leads plugs dis cap and rotor arm and iv been through the wiring its all ok temp sensors ok tps ok any help would be appreciated
Old May 1, 2018 | 09:15 PM
pete241's Avatar
pete241
Read my thread,im in the same boat,But you not found out your cam timing properly.
Ie 360 degree protractor and DTI gauge.
Race Yb Vernier pullys ?
Old May 2, 2018 | 10:09 AM
colins2's Avatar
colins2
The best way I have found to set the cams up is to find true TDC while the head is off using DTI gauge and a timing disk been a while but if I remember correctly there is a 10degree dwell period when the piston reaches the top of the bore until it starts to move down true TDC is in the middle of whatever the calculated dwell period is once that is done and you have an accurate way of repeatable setting this move on to the valve timing usually the cam will come with a spec 118 BTDC for my cam if I remember once I set the timing on std mark and it is on my true TDC mark set the timing disk to 0 and turn the crank to my cam setting 118 BTDC then I adjust the cam again by using a DTI on the inlet valve if you have set the timing up close and have your cam pulley set in the middle of the slotted adjustment holes you should be able to set the valve to full lift by turning the cam pulley make sure that the crank is still at 118 or whatever your cam spec is nip all the cam pulley cap screws up and turn the engine over by hand before starting.
I have only ever done 2 YB engines and had issues with the first, had to check it and redo the exhaust cam as it was out but cant remember what it was.
jonfoc
16
Sep 11, 2018 05:35 PM
SmudgerByName
52
Jul 28, 2016 06:14 PM
Nov 1, 2015 06:53 PM
dombanks
Sep 21, 2015 08:38 PM
mint_s2
Sep 2, 2015 08:58 AM
