3dr misfire
Old Apr 7, 2013 | 10:44 PM
mitchymitch's Avatar
mitchymitch
Default 3dr misfire
Hi help needed for my 3 dr it misfires at 2100 rpm in every gear both going up the rev range and coming down causing the red engine light to come on. Its most annoying in traffic.
thanks in advance
Old Apr 9, 2013 | 02:44 PM
mitchymitch
Anybody?
If it helps ive fitted wasted spark to try and cure it but its still there. Any suggestions how to check the loom, can it be done in situ?
Old Apr 9, 2013 | 06:03 PM
oldford's Avatar
oldford
The engine light only comes on when a sensor is completely out of range.
Knowing which sensor saves a lot of time.
Codes can be read (when the light is on) with a led-tester or Star-tester.
Old Apr 9, 2013 | 06:38 PM
mitchymitch
Thanks for the reply so if i get a tester i run the car it misfires and i plug the said tester into where.... get the code and refer that code to see where the fault is. Sorry i know nothing about this is it as easy as that then?
Old Apr 9, 2013 | 07:06 PM
Rossy43's Avatar
Rossy43
Fiesta ZS. FF feat nov'11
Dont think the management gives codes.
The led tester just blinks a number of times and that indicated a potential issue, i think.
Old Apr 10, 2013 | 06:46 AM
oldford's Avatar
oldford
Or make the tester yourself. These old led- and star-testers are hard to find.
How to make your own led-tester and read codes: http://www.bigturbo.co.uk/main7.htm
Old Apr 10, 2013 | 08:11 PM
mitchymitch
Thanks very much for the replies and i understand how to build a tester from the diagram from the link provided many thanks. If i may i would like to pick your brains one more time, the misfire only occurs under load IE it wont do it when you free rev it only under load being driven. so do i plug in the LCD before or after the light comes on. What i mean is do i drive it the light comes on i plug in the wire and it will provide the code.
cheers
Old Apr 11, 2013 | 07:11 AM
oldford's Avatar
oldford
It doesn't matter when you connect the "tester".
What does matter is that valid codes can only be obtained when the engine light is on.
Switching off the engine and restarting it will clear the codes.
Sierrasideways
Oct 8, 2015 06:37 PM
martynhomer01
Oct 1, 2015 12:05 AM
IainRS1700T
Sep 25, 2015 06:44 AM
Brickhouse
Sep 21, 2015 11:00 AM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
