Electric Window must be possessed!
Old Mar 27, 2013 | 08:09 PM
sbrophy84's Avatar
sbrophy84
Default Electric Window must be possessed!
Hi all, I have a problem I was hoping to get some help with: my fiesta mk6 2004 flame has a strange tick where the passenger window only opens when the drivers switch is used. Motor seems fine and more oddly the passenger switch when pressed will interrupt the window opening from the drivers side so there must be a signal coming from it! Any ideas? Is there something between the switch and the motor that could be faulty??
Any ideas gratefully received!!!
Steve
Old Mar 27, 2013 | 08:18 PM
gingerturbo's Avatar
gingerturbo
The annoying ginger guy
Either the main switch(drivers side) is faulty or you have a wiring/signal issue
Old Mar 27, 2013 | 08:23 PM
sbrophy84's Avatar
sbrophy84
Yeah the drivers switch seems to do everything it's supposed to its just the passenger side, thanks for the reply
Old Mar 27, 2013 | 08:35 PM
gingerturbo
Check the loom where it goes through the door into the car by the hinges as it may of got trapped/pinched also check the wiring/plug in the door cards
chowfornow
14
Jan 5, 2019 09:01 PM
Nov 1, 2015 06:53 PM
stevecfrst1
Sep 30, 2015 05:18 AM
cossie330
Sep 27, 2015 04:13 PM
IainRS1700T
Sep 25, 2015 06:44 AM
