ST170 Solida Flywheel conversion, which one?
Old Jan 22, 2013 | 10:58 PM
Fraserb's Avatar
Fraserb
Default ST170 Solida Flywheel conversion, which one?
Ok after speaking to several people I am going to for a solid flywheel conversion but which one do folk recommend? The TTV, CFM Spec Kit, or Clutchmaster kit also from CFM?
Old Jan 22, 2013 | 11:42 PM
JOHNDQ's Avatar
JOHNDQ
Are they ok to use on the ST170 mate, i work at a Bosch garage and we been told not to fit them to some cars as theses been engine/gearbox and management problems due to all the vibrations being pasted though them that the DMF will normally take up
Old Jan 23, 2013 | 10:25 AM
Fraserb's Avatar
Fraserb
as far as I'm aware they are ok to use. With the Aluminium Flywheel you do get some clutch chatter but if you want to avoid this there is a solid steel fly available that eliminates this. As long as you have the correctly sprung clutch pressure plate it absorbs the vibrations instaed of the DMF.
mk3ste
Oct 17, 2021 10:09 AM
arkeye
Ford Focus ST
Feb 20, 2016 01:22 PM
Mark_
14
Jan 16, 2016 05:27 PM
SMILER258
Sep 28, 2015 09:04 AM
Marv888
Sep 26, 2015 03:44 PM
