another no spark cossie :P
Old May 10, 2012 | 08:35 AM
derekd's Avatar
derekd
Default another no spark cossie :P
well i have just built up my 4x4 to 2wd !! 2wd engine ,2wdecu,2wd wiring loom, all set to go and i have no spark when turning the car over have changed all these parts still same problem !! cps,ecu,chip,coil,dizzy,rotor,ign amp,loom,phase, relays, running out of ideas here i get a spark when turned to pos 2 and nothing when cranking !! fuel pump primes and have fuel pressure just no spark !! all 4 lugs are there on the pulley and checked power at coil and sensors and have changed the factory alarm relay box and have no aftermarket alarm on the car !! anyone ideas before i give up :P and timing is spot on too
Old May 10, 2012 | 08:41 AM
rog's Avatar
rog
When you say "my 4x4 to 2wd new motor" what do you mean, a 4x4 engine in a 2wd? What engine and sensors, and what loom?
Old May 10, 2012 | 08:45 AM
derekd's Avatar
derekd
i put in a 2wd engine m8 with 2wd loom and l6 ecu
Old May 10, 2012 | 05:21 PM
Alvyn's Avatar
Alvyn
wire going to the phase sensor's wrong way at a guess
Old May 11, 2012 | 09:53 AM
derekd's Avatar
derekd
nope mate they are round the right way
Old May 11, 2012 | 12:19 PM
opposite lock's Avatar
opposite lock
A quick pot shot, do you have the correct TPS for L6
Old May 11, 2012 | 12:56 PM
martysmartie's Avatar
martysmartie
TPS won't prevent a spark though, my money is on the ECU/chip or bad CPS.
Martin
gcfcos
59
Oct 6, 2015 05:04 PM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
deathrider666
Sep 28, 2015 06:12 PM
cossie330
Sep 27, 2015 04:13 PM
Russ Payne
Sep 25, 2015 08:29 PM
