bremdo pads removal
Old Apr 12, 2012 | 05:42 PM
crock's Avatar
crock
Default bremdo pads removal
how do i get the pins out,i think they are rusted in,i need to replace the pads on my focus rs,helpppppppppppppppp
Old Apr 13, 2012 | 10:31 PM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
hammer and a drift/punch.
no other way really.
Old Apr 13, 2012 | 10:52 PM
langer's Avatar
langer
You need to knock them out of the ends with a punch and then get some mole grips on them in the middles and wiggle them or tap them with a hammer through until you can get a hold of the ends and pull or tap them again.
Old Apr 13, 2012 | 11:05 PM
RS2000CUSTOM's Avatar
RS2000CUSTOM
Sacrifice the pins and cut them in the middle
Then you will only have to knock out the pins one hole at a time
As the Brembo caliper is alloy they can snap off where the pin corrodes into them so a set of pins is cheaper than a pair of calipers
I did exactly this when replacing discs and pads on a customers Megane F1 Alonso Special and the pins were solid in the calipers
Old Apr 14, 2012 | 02:13 PM
crock's Avatar
crock
ill have a go , cheers lads
boeb
Jan 9, 2020 05:11 AM
Nov 1, 2015 06:53 PM
Orion_Gav
Sep 29, 2015 04:50 PM
