ABS light
Old Mar 17, 2012 | 10:22 PM
clarkyp's Avatar
clarkyp
Default ABS light
Hi all where should the abs light be on a 91 4x4 sapphire i cant see any where when ignition is turned on ??
cheers all
Old Mar 18, 2012 | 12:10 AM
daz1968's Avatar
daz1968
If its same as 3 door it is 2 small orange lights on the dash cluster
Old Mar 18, 2012 | 12:16 AM
JFB Tech's Avatar
JFB Tech
Not entirely sane
It's in the centre of the instrument panel, above the rest of the warning lights. Non ABS cars had a ribbed blanking plate here instead of the warning lamp.
Old Mar 18, 2012 | 12:28 PM
clarkyp's Avatar
clarkyp
Hi it has abs well suppose to it has the pump & all the sensors but no light on the dashboard ??
Old Mar 18, 2012 | 12:49 PM
clarkyp's Avatar
clarkyp
Right just checked it has the ribbed part either side but a smooth rectangle in the middle i take it this is where abs light is suppose to be so clock out to see whats their !!!!
Old Mar 18, 2012 | 02:34 PM
JFB Tech's Avatar
JFB Tech
Not entirely sane
Yep, that's the one. It should have it's own lamp holder, it isn't wired with the rest of the warning lamps.
tankybaby66
Feb 6, 2016 02:24 PM
muzzman1
Sep 30, 2015 08:59 PM
