Engine dying in chic what to replace with
Old Mar 6, 2012 | 06:49 PM
mobo's Avatar
mobo
Default Engine dying in chic what to replace with
I have a 02 plate ford focus chic which has done over 130000 I brought it as i was told the engine had been rebuilt however this turned out to be false. Now the engine is dying and very tappety. It is sending oil to the spark plugs and have been told this would require a full engine rebuild.
I would like to put a new engine and clutch in there however i dont know the engine code. Also could i put a more powerful version of the 1.6 engine in there like a zetec s engine from the fiesta?
will it be a direct fit or will i need to replace the gearbox and all the other stuff on the engine.
thanks in advance
Old Mar 6, 2012 | 06:54 PM
adam151082's Avatar
adam151082
anything is fixable, is it the head thats knackered?
If it were me id try and avoid a new engine, id rather a new car.
Old Mar 6, 2012 | 06:58 PM
mobo's Avatar
mobo
Been told its the piston rings by more then one garage
Old Mar 6, 2012 | 07:03 PM
gouch1's Avatar
gouch1
the gearbox should fit most ford engines
Old Mar 6, 2012 | 07:04 PM
adam151082's Avatar
adam151082
If it were me id weight the car in and buy another
Old Mar 6, 2012 | 07:07 PM
mobo's Avatar
mobo
Will anything else need to be changed i.e altenator coilpack etc or will the standard ones do
j.hammond1
30
Oct 31, 2021 05:28 PM
SmudgerByName
52
Jul 28, 2016 06:14 PM
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
Anutternutter
24
Aug 31, 2015 01:24 PM
Ben26
Ford Focus Diesel
Aug 18, 2015 03:42 PM
