Twin pumps
Old Apr 17, 2004 | 01:48 PM
Default Twin pumps
Whats the best way to run twin pumps on a 2wd sapp? t piece the the tank and run the pipes to the the pumps and put a 8mm pipe all the way through to the engine bay?
any ideas
kind regards
Old Apr 18, 2004 | 12:07 AM
PJay's Avatar
PJay
Personally i don't like twin pump setup'd due to the fact that if one ppump fails the engine will run lean and melt, it is much better to use 1 uprated pump
Old Apr 28, 2004 | 10:37 AM
mates 4x4 has got twin pumps,t-piece from tank into pumps then t-piece back into single pipe.wont supply any more fuel but will make sure it never runs lean if one pump is weak.his fuel filter has been moved in an rs-turbo bracket under the floor,nearside near the back seat,other pump where the filter used to be.it is currently running stage three plus gas with no problems.
Nov 1, 2015 06:53 PM
sridgett
Oct 1, 2015 07:30 PM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
Steve Escos
Oct 1, 2015 06:57 AM
20/20 vision
Sep 29, 2015 11:27 AM
