Help with these codes please
Old Feb 23, 2012 | 01:48 PM
karlos09's Avatar
karlos09
Default Help with these codes please
Focus diesel 2001 y reg codes are c2097 and 0097 ,abs tracks ion control and handbrake lights are on cheers Karl
Old Feb 23, 2012 | 07:19 PM
GVK.'s Avatar
GVK.
Can't find any info about either of those codes.
Were there no code definitions on the code reader? (guess not)
Really need to know the definitions before going any further...
If all the warnings are on, I would check all the ABS fuses and take off the ABS module connector, check for corrosion/water ingress, check for power/grounds on the connector.
Could be the actual ABS module faulty, but only a guess from afar!
Old Feb 24, 2012 | 04:27 PM
steve4i's Avatar
steve4i
abs sensor code unsure of what 1 tho lol
Old Feb 28, 2012 | 06:11 PM
karlos09's Avatar
karlos09
when we had snow other week drove down road about 500 yards touched the brakes felt abs come in and all these lights came on thought id stalled the car dipped the clutch ,engine still running lights still on so just run it as is ,then noticed that abs no longer works
Old Feb 28, 2012 | 06:15 PM
RichieST's Avatar
RichieST
Which diagnostic scanner did you get these codes from?
Fiddy
21
Sep 29, 2015 06:10 PM
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
oilman
Sep 23, 2015 11:21 AM
Digispurs
Ford Focus Range
Sep 16, 2015 09:47 PM
