Clifford Concept 450 HELP!!
Old Feb 9, 2012 | 04:49 PM
bobster1982's Avatar
bobster1982
Default Clifford Concept 450 HELP!!
I have had a concept 450 professionally fitted but as the installer didn't have a 5 button remote he couldn't setup the prox sensor I bought separately for me. I went out and bought a 904075 5 button remote and went to program it in using the autolearn programming sequence and the alarm accepted it.
However it wont arm or disarm unless I press the clifford shift button once and then the lock/unlock and none of the other buttons work at all apart from the * button that seems to activate remote valet.
Is there some way to program these 5 button fobs in? If I can get it to work right then I program the prox by transmitting ch16.
Thanks,
Rob
Old Feb 9, 2012 | 05:08 PM
fiend's Avatar
fiend
It sounds like you need to use Cliffnet and the cable that connects your laptop to the alarm. Check ebay for the cable.
Or just take it back to the person who fitted.
Old Feb 9, 2012 | 05:16 PM
bobster1982
I've managed to get the fob programmed by manually setting each button.
unlock lock now works.
boot now works.
what outputs do you give to * and ** as defaults?
and does anybody have a 5 button remote table so I know what I'm doing with the shift button??
original
Apr 28, 2026 05:20 PM
Steve Escos
Alloy wheels and ICE for sale
14
May 8, 2019 02:45 PM
Danielbetty
Oct 3, 2015 06:01 PM
RSBryden
Sep 6, 2015 08:39 PM
Aug 29, 2015 08:16 PM
