Zetec oil filter onto escort rs turbo
Will a zetec oil fiter be o.k to use on a escort rs turbo?
What engine is in the car? A cvh or zvh? if cvh then why noy just buy a cvh filter. They are about 3 quid from any motor factors. If zvh then im led to beleive a fiesta 1.25 works well and gives good clearence wheras the 2.0 zetec one is a tight fit
Originally Posted by CosworthGuy
(Post 5792740)
didnt fit & the only one i had knocking around was an elf600 which is for a zetec as it fitted i put it on the car has not been used since just wanted to know if it will be o.k, if not ill just get a replacment cheers. |
If it fits correctly and seals ok then i wouldnt worry about it really. As long as its not catching anything and the threads are ok id say fit and forget
Believe the threads are ok, but the Zetec ones are longer (the older ones anyway)
yeh it is longer,there are no clearence issues
i will just keep an eye on it. cheers guys. |
A Zetec oil filter (EFL600) will be absolutely fine. They are a little longer and have a non-return valve fitted internally.
I buy the EFL600 filters by the pack. I use them on my CVH, 1.25 Fiesta (makes them easier for clearance when removing), DOHC (should be an EFL90) and have never had a problem yet. |
Originally Posted by iansoutham
(Post 5793779)
© 2024 MH Sub I, LLC dba Internet Brands
