Focus engine replacement
Old Jan 12, 2012 | 06:51 PM
mark.crook@me.com's Avatar
mark.crook@me.com
Default Focus engine replacement
hi all,
recently purchased 2004 focus 1.8 di estate with bottom end banging with intention on replacing the entire block.
i managed to swap over all the ancillaries and fit the new(ish) engine, no problem, good compression from new block.
i believed that it was all timed up correctly however it would not start or run, , i came to the realisation that the bottom crank needed to be turned 360 to bring the pump on time.
i managed to get the car started after injector pump timed correctly with a little help from "are you startin" we drove the car around the block a few times, up to temperature and turbo working but the engine had quite a rattle still so i decided (luckily) to not drive the car home that night as i thought the pump may have been a tooth out.
the next morning the car was a complete non-starter so i adjusted the pump timing very slightly. tried boosting the battery still nothing, so i decided on some help from cold engine starter and BANG!! piston four is now hitting the valves
thank god i still have the old head!!!
does anyone have any idea on what may have happened here, im guessing the cambelt slipped a tooth because the cold start shot the pistons back the wrong way, never ever using that crap again!!! i checked the voltage of the glow plug/injector rail from cold start and all was good so i have no idea why it did not start the next day. what voltage should i have at the glow plugs???
i have had the engine mounts off 5 times now and this is getting extremely tedious.
Old Jan 12, 2012 | 09:01 PM
Churtz's Avatar
Churtz
I imagine when the timing slipped when it was warm. So being warmer it had enough compression to keep running. From cold, no compression, no start. I never use easy start
Old Jan 16, 2012 | 11:01 PM
mark.crook@me.com
whoooo, car is now running!! it turned out that the valves were not hitting after all.
we decided to attempt re-timing before changing any parts on the head, turning over by hand we found no "chinging" at all. found the noise to be coming from the starter motor/ring gear. deciding against using cold starter again we primed the deisel header tank with deisel and towed the car to start it, PERFECTO! car starts on the button from cold now but the starter motor chings a bit, not going to kill me...
mass air sensor needs replacing as turbo is a bit intermittent.
my next issue is that i have found oil spluttering out from the intercooler pipe, removed pipe and sure enough there is quite a bit of oil in there. im thinking it can be one of two things, either i have filled the engine with too much oil or the turbo is on its way out, possibly the reason the old engine failed. the reason im not thinking 100% turbo is because the exhaust gasses are completely clear where id expect too see some black smoke??? have found a genuine turbo repair kit quite cheap so may attempt a turbo refurb. any input you can give is much appreciated.
salsheikh
Ford Focus ST Parts for Sale
Oct 6, 2019 07:56 PM
salsheikh
Ford Focus RS Parts for Sale.
Aug 20, 2015 12:22 PM
taylora1409
Aug 12, 2015 12:06 PM
