Any more ideas please
Old Feb 21, 2005 | 08:36 AM
Lou Lou.'s Avatar
Lou Lou.
Default Any more ideas please
hi another poxy fiesta with idle probs
brand new iscv
brand new tps
throttle bodie cleaned out
revs still stickin bout 1500 sometimes huntin between 1500 - 1800
anymore suggestions welcome or even if u can suggest somewhere i can take it 2 to get it sorted cos its doin my head in
thanks in advance
Old Feb 21, 2005 | 05:13 PM
Lou Lou.'s Avatar
Lou Lou.
please anyone got any ideas its startin to do my f**kin head in also discovered a water leak 2day
bloody car
Old Feb 21, 2005 | 07:35 PM
Al Bags's Avatar
Al Bags
Hi Louise : )
What management is on this car? Saves me looking it up at work tomorrow!
Have you checked around for air leaks, anything after the throttle plate? It's possible to get strange things happening when something is off in the inlet manifold area.
Also worth looking at is any warm-up sensor .. for operation or bad connections. One of these failed can alter fuelling cos the car thinks it is cold, when it's not!
Some management systems remember (they learn) tps/fuelling settings. Some can be reset by disconnecting the battery for a while. Before you try this, make sure you got your radio codes and set the alarm off with key .. or manually!
Old Feb 22, 2005 | 07:25 PM
sammy's Avatar
sammy
Originally Posted by Al Bags
Hi Louise : )
agreed, have you tried setting the base idle to 700-750rpm with the idle valve disconnected, then reconecting the idle valve, leaving the engine to idle (no reving/blipping of the throttle) for 10 mins for the ecu to remember its new idle value's
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
Fezman1
Oct 2, 2015 01:22 PM
Orion_Gav
Sep 29, 2015 04:50 PM
rogerxr3i
Sep 13, 2015 06:56 PM
