Heating will not come on
Old Oct 11, 2011 | 06:00 PM
enner100's Avatar
enner100
Default Heating will not come on
I have a ford fiesta zetec. I recently put it in for its MOT and had a service done. It was not until yesterday that I tried to put the air conditioning on and it did not come on (2.5 weeks after service). It does not work with hot or cold air.
I have checked the fuse and that is ok. What else could I check?
Old Oct 11, 2011 | 06:29 PM
gosa264's Avatar
gosa264
I know the heaters failing was a common problem on the mk4 and 5 fiestas not sure about air con though you could try the heater control valve there a guide on how to fix them on fiestaguides.co.uk. heres the link for it http://www.fiestaguides.co.uk/conten...rol_valve.html
Hope this helps mate
Old Oct 11, 2011 | 06:33 PM
LukeDaisley's Avatar
LukeDaisley
if it the blowers that are inoperative, a common problem with them is the thermal trip fuse. which is a little green box/plug behind the glove box, next to the blower motor.
Old Oct 11, 2011 | 06:41 PM
enner100's Avatar
enner100
Thanks for the replies. I will check that as you don't hear the blowers at all when i try and put it on.
Old Oct 13, 2011 | 03:12 PM
enner100's Avatar
enner100
As you can tell I am no car expert. How do I get to that to check it?
Old Oct 13, 2011 | 03:26 PM
enner100's Avatar
enner100
The model is a fiesta zetec s 1.25 engine and year 2000
I think it may be something to do with the blower motor. It does not work whether it is on 1, 2, 3, or 4. It also does matter whthere it is switched to blow hot or cold air.
I have rechecked all the fuses in the cental fuse box. I have also checked the fuses in the auxilary fuse box.
Could it be the air conditioning relay? Is there way to check if a relay is broken or would it be just best to replace it and see if that fixes things?
Could this have been done when it was serviced? The heating/blower was working before I got my car serviced and it's MOT done. Unfortunately for me the first time I tried to use the heating was 2.5 weeks after the service. So I feel a bit of a fool going back the garage and saying since you done the service and MOT the blower is not working.
Old Oct 13, 2011 | 04:48 PM
LukeDaisley
https://passionford.com/forum/techni...n-problem.html
I know your car is a fiesta but this might help.
Old Oct 13, 2011 | 04:57 PM
enner100's Avatar
enner100
Thanks. I think this is too big a job for me. I will take it back to the garage.
Old Oct 17, 2011 | 12:26 PM
martysmartie's Avatar
martysmartie
If it doesn't work on any power position you have either a power, switch or motor fault, it should always work on Pos 4 as this has a live feed!
Martin
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 5, 2015 08:12 PM
cossie09
Sep 10, 2015 06:56 PM
