ignition barrel removal
Old Sep 13, 2011 | 02:23 PM
Roberto_98's Avatar
Roberto_98
How ye lads
Default ignition barrel removal
due to some undesirable characters trying to steal my car i now have to put in a new ignition barrel. i've gotten hold of a second hand ignition unit. i only want to swap the barrels out however as i dont want various keys belonging to the car. it's a 90 mk 4 xr3i. Any ideas?
Old Sep 13, 2011 | 06:14 PM
martysmartie's Avatar
martysmartie
Just fit the new switch to your barrel, assuming it's not damaged preventing you from doing so.
Martin
Old Sep 14, 2011 | 01:27 PM
p100rallyesport's Avatar
p100rallyesport
to get the old barrel out you need to remove all the cowling asuming the scum havent allready.
you need to put your key in the barrel and turn it to the first position.
if you look on top of the barrel housing you will see a little round thing if you get a small screwdriver and push it down it will release the barrel and you just pull it out.
you still ned the key turned to position 1 while you push the locking tab down like wise to refitting the new barrel turn key to number 1 hope this helps
boeb
Jan 9, 2020 05:11 AM
Orion_Gav
Sep 29, 2015 04:50 PM
