need some help
Old Feb 13, 2005 | 04:35 AM
jonnyfrst's Avatar
jonnyfrst
Default need some help
hello all im new here and need a bit off help
i need a little advice mate on the following
i have just got a fiesta rs turbo and its not running right. Here is the
problem i think it is Its not running tho the engine does run. It suffered
from backpressure and oil went everywhere and I don't know the full damage
The engine runs at high revs, lots of white smoke. Reckon the turbo may have
been damaged but thats what im not sure about and i need some help if i need
2 get a new turbo or get a new engine all together
also i know a escort rst engine fits into the fiesta but how much work would need 2 be done and fully running
cheers john rae
Old Feb 13, 2005 | 10:37 AM
rsjohn's Avatar
rsjohn
As long as the erst block has the hole for the flywheel it can be used on frst, you then need to fit the sensor and spacer and the frst flywheel with the pick up.
John.
Old Feb 13, 2005 | 10:49 AM
jonnyfrst's Avatar
jonnyfrst
what do u think about the engine mate or is it the turbo like just so i know what one 2 go for or just get the erst engine
Old Feb 13, 2005 | 01:00 PM
jonnyfrst's Avatar
jonnyfrst
i have just been told that it is back pressure so what does that mean now
just turned the car over, after a week of sitting she started first time, it idles at 2000 revs with a bit of blue smoke. burning oil smell too but the engine doesn't sound that rough. possibly needing a new turbo sounds as rough as a hippy bus i suppose but no sounds of metal on metal is what i mean
