Dashboard backlighting .
Old Jun 22, 2011 | 03:55 PM
albev's Avatar
albev
Default Dashboard backlighting .
I assume that this is on once you start the car up but mine only comes on when you switch the sidelights or mainlights on,......and when you brake !!, as i'm a mechanical novice i'm looking firstly at an easy solution such as a bad earth, but could you lads give me some more advice.
Many thanks in advance .
Old Jun 22, 2011 | 05:59 PM
The back lighting comes on with the sidelights, whether or not the engine is running, it's wired into the same position as the sidelights.
Old Jun 22, 2011 | 07:04 PM
RichieST's Avatar
RichieST
You've got the wrong tail / brake light bulbs fitted, or they're fitted incorrectly.
What car by the way?
Old Jun 23, 2011 | 11:18 AM
albev's Avatar
albev
I have a Focus 1.8 LX hatchback, 03 reg, i did change a rear brake light bulb a few weeks ago but cannot remember whether the problem stems from that .
Old Jun 23, 2011 | 03:12 PM
RichieST's Avatar
RichieST
That will be your problem, guarantee it! Remove the bulb and see if it still does it.
Old Jun 23, 2011 | 04:30 PM
albev's Avatar
albev
I used an RW382 which caused the problem, on your advice i went to a motor spares shop and she gave me an RW 380 double filament bulb, problem solved, thanks very much .
Backlighting, mine comes on only when i turn on the lights, car running or not, is this correct .
Old Jun 23, 2011 | 05:14 PM
RichieST's Avatar
RichieST
Yes that's right, dash lights will only come on when you switch the lights on.
Old Jun 23, 2011 | 05:41 PM
albev's Avatar
albev
Thanks .
155lee
Oct 24, 2015 11:11 AM
andyrs1600i
Sep 4, 2015 06:34 PM
andyrs1600i
Aug 30, 2015 07:21 PM
frog
Sep 28, 2004 11:36 AM
Mark V8
Sep 25, 2004 10:59 PM
