2wd and 4x4
Old Jun 6, 2011 | 08:28 PM
burnhamshaun's Avatar
burnhamshaun
Default 2wd and 4x4
Is the lock set and fuel pump cradle the same on a 4x4 as 2wd as a friend of a friend is gonna be stripping his concourse saph and almost everything is brand new so I would like these if they are the same
Old Jun 6, 2011 | 08:55 PM
dojj's Avatar
dojj
Resident Wrestling Legend
No differnt
that's not to say you couldn't use them though
the 90 spec stuff operates differnt stuff in the drivers door barrel and the boot lock is key only rather than popped but as for the cradle for the fuel pump, isnt the later stuff internal pump?
That said, you can easilly change you boot catch over for the cable operated version and the door locks would also benifit from the 90 spec single cable rather than multiple rod set up on the 2wd cars . Unless you've got the 4wd car and his is the 2wd variant
Old Jun 6, 2011 | 08:57 PM
dojj's Avatar
dojj
Also you may need to fettle the inner door panel by a few mm as the 90 spec motors will need some clearance forthright additional plastic covers. But you could also get the metal lock cover as used on the later spec front rear door inner channels to give you a bit more peace of mind
Old Jun 7, 2011 | 05:48 PM
Fuel pump cradle is the same afaik, defo both external pumps, I have a xr4i cradle on my 2wd and it's identical.
Old Jun 7, 2011 | 06:23 PM
martysmartie's Avatar
martysmartie
I think the Escos had integral pump.
Martin
Old Jun 7, 2011 | 08:39 PM
Escos is indeed internal, but author has a 2wd and mate has a 4wd, both sierra sapphy.
Nov 1, 2015 06:53 PM
cossie330
Sep 27, 2015 04:13 PM
DavidK
Sep 27, 2015 02:55 PM
mpilk
Sep 27, 2015 09:21 AM
Russ Payne
Sep 25, 2015 08:29 PM
