help mk4 escort lower steering column bush
Old May 26, 2011 | 07:58 PM
cossieant380's Avatar
cossieant380
Default help mk4 escort lower steering column bush
hi can anyone help i am changing the botton steering column bush on my f reg esc cab but struggling
which way does the spring go
Old May 26, 2011 | 08:06 PM
jonesymk2's Avatar
jonesymk2
the smaller end of the spring sits against the bush
Old May 26, 2011 | 08:09 PM
cossieant380
but doing that it will not stay in outer column it just pops out
Old May 26, 2011 | 08:13 PM
cossieant380
how do i post pics on here to show you
Old May 26, 2011 | 08:55 PM
cossieant380
anyone got any answers please
Old May 30, 2011 | 11:32 AM
jonesymk2's Avatar
jonesymk2
i think it is so that it keeps pressure on the 2 bushes,if you put the spring the other way round it doesnt do anything so whats the point of it being there atall,put the bush on the column then the spring on the bush with the small end of the spring against the bush,then when you put the outer column on make sure the groove in the outer column lines up with the raised part on the bush,then you just push the outer column down on the spring and tighten the 2 13mm nuts to secure it to the pedal box
Old May 31, 2011 | 06:29 PM
djvu's Avatar
djvu
fucking hell i done mine two weeks ago and im struggling to think where it went
Vincereese
Jun 1, 2023 09:14 AM
FlashRS
Sep 14, 2015 12:36 PM
Vincereese
Aug 18, 2015 03:57 PM
Vincereese
Aug 16, 2015 06:38 PM
A.t.p
Aug 15, 2015 11:37 AM
