focus miss fire... coil pack?
Old May 10, 2011 | 08:39 PM
shunn's Avatar
shunn
Default focus miss fire... coil pack?
hi all
i have a 2003 1.6 focus zetec which has been missfiring at low revs. i have read about coil packs, ht leads and spark plugs to change. just wondered if this is right and what to try first?
cheers
stuart
Old May 11, 2011 | 01:32 PM
A coilpack is the most likely, rather than replace do you have a mate with a focus so you can swap bits to try and eliminate duff parts, as just swapping can get expensive, how are the emissions, how does it idle ?
Old May 11, 2011 | 09:33 PM
shunn's Avatar
shunn
no dont know anyone else with a focus.
it is a bit rough on idle , like it could stall.
i have got some spark plugs as i was changing them as its due a service anyway, so il change them and see
Old May 13, 2011 | 07:52 AM
shunn's Avatar
shunn
i changed the spark plugs and that seems to have done the trick
Old May 24, 2011 | 08:13 PM
shunn's Avatar
shunn
after running the car for a week or so it seems to still misfire a bit at low revs when cold, but not as bad as before. may try the leads and coil pack next
stuart
Old May 25, 2011 | 01:13 PM
Focus_2008's Avatar
Focus_2008
Steve_2009
As Tabetha said, coil pack is more than likely as Fords r renouned 4 the coil packs, has the car got an engine management light on? If so its more likely the coil pack as mine went on my Focus, same year n size lump as urs
Old May 25, 2011 | 01:51 PM
CarParts Express's Avatar
CarParts Express
http://www.carpartsexpress.co.uk/Foc...34-87-360-602/
as said pretty common and sell loads of these
Old May 25, 2011 | 02:05 PM
focus 4x4's Avatar
focus 4x4
As stated already Focus' eat coil packs!
Old May 25, 2011 | 03:55 PM
H3lsing's Avatar
H3lsing
ffoc.co.uk
My coil went and had the same sympthons as described, misfiring etc. I knew it was the coil, so safe in that knowledge I went off to the motor factors to collect one. Installed in 5 minutes and was smooth as silk running.
The next day misfiring again, checked everything over, lead, plugs, oils etc. No joy booked into garage and the spurious coil was at fault casue not generating enough volts. When buying the new coil buy from fords.
Old May 26, 2011 | 02:17 PM
mobb-black's Avatar
mobb-black
Focus coil packs go for fun, get a silver top coil pack n you'll never have problems.
Old May 26, 2011 | 07:29 PM
stevehannah87's Avatar
stevehannah87
Hi Shunn i had the same problem with my mondeo, under power at low revs it was terrible, misfiring like fuck then got slightly better as it got higher. I changed my plugs, leads and air filter with no real effect, i swapped the coil from my 1800 XR2i and it was cured instantly, all power right through the revs now. All the best
Old May 27, 2011 | 08:41 PM
shunn's Avatar
shunn
the engine light is not on,
would you change the ht leads aswel?
Old Jul 5, 2011 | 07:52 PM
shunn's Avatar
shunn
just to report i changed the lot, coil pack, leads and spark plugs and it now runs much smoother. got the lot for around 50 from local motor factors
cheers guys
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 5, 2015 08:12 PM
Nov 3, 2015 04:08 PM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
Sep 3, 2015 10:49 AM
