zetec conversion (clutch)
Old Feb 7, 2005 | 01:06 PM
16vzetec's Avatar
16vzetec
Default zetec conversion (clutch)
just to check before i buy one.
ive got a 1.8 zetec flywheel.
im using a rst gearbox.
so i asume i need a 1.8 zetec clutch? yeah??
will this be ok and will the starter motor meet up fine?
mike
Old Feb 7, 2005 | 03:49 PM
carlosl's Avatar
carlosl
as long as you got a 220mm flywheel from the 105ps model you can use an rst clutch.
Old Feb 7, 2005 | 04:10 PM
Red16's Avatar
Red16
if you used frst management, would it be run ok with the 220mm zetec flywheel and zetec crank position sensor?
Old Feb 7, 2005 | 04:31 PM
carlosl's Avatar
carlosl
I was using the 240mm flywheel from the 130ps model and was using fiesta turbo management.
A.t.p
Sep 29, 2015 05:04 PM
SMILER258
Sep 28, 2015 09:04 AM
