focus engine cooling fan multiplug burnt out.
Old Jan 26, 2011 | 10:28 PM
tonytantrum's Avatar
tonytantrum
Default focus engine cooling fan multiplug burnt out.
my fan stopped working the other day and the terminals in the multiplug for the fan have burnt out.
it was sent to fords by a previous owner with the sme problem and they fitted a new fan but it hasnt fixed the problem,
any ideas?
thanks tony!
Old Jan 27, 2011 | 07:12 PM
Are your fans seized ?, this will do it, fuse should have gone first, but things don't always work as they should.
Old Jan 27, 2011 | 10:49 PM
tonytantrum
nope the fan isnt seized its two years old and if you play with the multiplug wireing harness too the fans they work perfectley!
Old Jan 28, 2011 | 04:17 PM
martysmartie's Avatar
martysmartie
Perhaps the fans are pulling to much power, or the fans are running more than they should be?
Martin
Old Jan 28, 2011 | 04:21 PM
RichieST's Avatar
RichieST
I reckon you've got a bad joint inside the plug, it's causing a heat build up, thus a melted plug.
Old Jan 30, 2011 | 10:50 PM
tonytantrum
brought a second hand fan unit from ebay that i can honestley say that i wont be using! the risister on the bottom of the fan is really badley corroded so im using the multiplug from that fan which is in good condition and ive also cut a section of loom from a scrap focus which im going to solder and heatshrink on my car! bit pissed of about the ebay purchase but thats the risk buying secondhand parts even tho the seller discribed it as in good working condition!
cheers for your help guys i will update on my progress!
tony!
salsheikh
Ford Focus ST Parts for Sale
Oct 6, 2019 07:56 PM
salsheikh
Ford Focus RS Parts for Sale.
Aug 20, 2015 12:22 PM
Ben26
Ford Focus Diesel
Aug 18, 2015 03:42 PM
Old ford
Jul 31, 2015 06:50 AM
