Cambelt cover
Old Jan 9, 2011 | 06:20 PM
burnhamshaun's Avatar
burnhamshaun
Default Cambelt cover
What cambelt covers if any could I get for zvh
Old Jan 10, 2011 | 05:44 PM
burnhamshaun
up we go
Old Jan 11, 2011 | 06:44 PM
burnhamshaun
Tried looking for info on this and found nothing help me out know it alls
Old Jan 12, 2011 | 08:10 AM
JonathanJ's Avatar
JonathanJ
As far as I know there is nothing you can do as block is taller hence the need to use small cam belt tensioner and different profile of the oil pump , I have to say that if you have built one of these there is not a lot of need for a belt cover other than to keep debris from entering belt , but as long as you aint going to drive over gravel car parks too fast should not be a problem , and if at all worried use the bottom of the zetec one as it would be more likely to suffer from debris than the top .
Just keep rags and loose objects well clear when engine running and bonnet up
Mark RS
Mar 5, 2021 06:08 PM
fordrallycar
Sep 30, 2015 07:57 PM
Fil
Sep 30, 2015 12:08 PM
