.....SPEEDOMETER & MILEOMETER......
Old Mar 28, 2004 | 11:48 PM
Default .....SPEEDOMETER & MILEOMETER......
I HAVE NOTICED THAT MY SPEEDOMETER & MILEOMETER IS NOT WORKING, I'VE PULLED OUT THE CLOCKS AND CHECKED IT OUT, ALSO CHECKED THE CABLE DOWN TO THE GEARBOX !!! STILL NO JOY!!!
DOES ANYONE KNOW WHAT IT COULD BE PLS ??!!
***S2 ESCORT TURBO '89***
Old Mar 29, 2004 | 12:42 AM
Rick Schubel's Avatar
Rick Schubel
Hi mate,
Try putting the car up on stands and running it in gear, with the clocks out of the dash. If you see the cable turning, then the problem must be in the speedo gear assembly somewhere.
What sort of vehicle do ya have??
Regards,
Rick.
Old Mar 29, 2004 | 12:45 AM
Rick Schubel
Doh!!
I see you have an S2. At least it will have a mechanical speedo, instead of an electronic one!! Should be an easy fix.
Regards,
Rick.
