Saph cos hyd lifters
Old Mar 28, 2004 | 11:11 AM
Default Saph cos hyd lifters
I've just fitted a new set to my cos,do they take a while to settle in/fill with oil? Been for a quick blast and left it ticking over till fans came on and went off but they are still rattling.
Old Mar 28, 2004 | 01:05 PM
swerv's Avatar
swerv
gen ford??
they do take a while to settle
Old Mar 28, 2004 | 08:45 PM
You should of left them soaking in oil for a few days first mate
Old Mar 28, 2004 | 10:28 PM
swerv's Avatar
swerv
not at all this wont make any difference , the lifters should be fine whether left in oil or not , they might take a while to settle in!!
just hope you used gen ford ones that all , i personally dont like the oe spec ones floating around which are very cheap
Old Mar 28, 2004 | 10:46 PM
have you put the INA ones in? they are fine as they are ford o.e spec,try holding at higher revs for 1-2 mins,if not check your cam timing-regards PJ.
Old Mar 29, 2004 | 12:27 PM
Dave Henshall's Avatar
Dave Henshall
pj - just out of interest,,,, why would the cam timing affect how they pump up??
Old Mar 29, 2004 | 12:30 PM
Dave Henshall
also..
while mine is stripped down at the moment, i thought id have aplay with the followers...
held them upside downwith the pin hole pointing down and plunged the pistoin in out several times - thick gey black oil came out of several of them - ive fleft them soaking in degreaser and re plunge dthem so thay are now all nice and free and have left them soakin gin some nice new mobil 1 - will plungen them agian while submersed in oil and get them back in - will be interesting to see how they behaive now...
Old Mar 29, 2004 | 04:36 PM
Cheers for replys.
Not gen ford as I did'nt like my local dealers price,£23 each!
They have settled down now thank you.
Just needed a bit of reassurance yesterday!
Old Mar 29, 2004 | 06:14 PM
Dave,oil pressure would regulate how tappets pump up,but cam timing wouldnt as oil pump drive is still spinning at same speed-regards PJ.
Old Mar 29, 2004 | 06:53 PM
Dave Henshall
thats what i thought, was that a a typo back there...
Old Mar 29, 2004 | 07:28 PM
i seen yb's with the cam timing a tooth out, and it sounded like noisey tappets but it was light piston to valve contact. one to look out for.
Old Mar 29, 2004 | 07:40 PM
Dave Henshall
point taken - as whats happened with mine by the looks of it - all 4 pistons have 2 slight marks where the inlet valves have graced their tops at some point - tuh tuhtuh
Old Apr 15, 2004 | 07:55 PM
Dave Henshall
all rebuilt now, and they are fine - no noise, no tappetty tap, no clicking , when hot or cold - jobs a good un and thats with the old tappets - just cleaned out thouroughly
Old Apr 15, 2004 | 08:03 PM
Dave, how d'you clean them ?
Old Apr 16, 2004 | 07:42 AM
Dave Henshall
remove them with a valve lapping in sucker(not a magnet - as this may magnetise the top causing swarf/fillings to gather and will cause the cam lobes to wear out very quickly. also note the location of each tappet as it will be bedded in to the location it has come from.
leave them soaking upside down in a tub of degreaser (i used diesel and parafin mix) then with a pair of snipe nose pliers, holding then tappet upside at around 45 degrees down with the oil hole on the side pointing down aswell. grab the plunger in the bottom with the pliers and slowly but firmly push it in and out, this will force the old oil out of the hole form inside the tappet - mine looked like tar do this several times and even do it with the tappet submerged in degreaser , you will notice that the plunger will work freeer and freeer to the point where when you pull it up it will drop back in under its own weight. leave out to dry overnight upsidedown and pump the bottom rapidly the next day to ensure no more oil/degreaser comes out the small hole. now leave them soaking in some new synthetic engine oil while pumping them in/out under the oil, leave them upside down in the oil for a day and repeat the nest day .
finally refit them by drooling new oil down the galleries and recesses where they fit in the head and put them back in the original locations. drool more new oil over the top and then refit the camshafts (and find 4 of the studs are actually stripped and need helicoiling ) and time her up.
i wound the engine up on the starter for around 30 secs with the coil ht lead disconnected to get some oil pressure up. then reconnect and all was good - no more tappet noise so this it seems is all that goes on them - they get all gummed up with old carbonated oil and cant pump up easilly -causing the tapperty noise when cold.
Old Apr 16, 2004 | 07:59 AM
Excellent, sounds like a worthwhile thing to do even if it means I have to buy some new ones in the end.
Thank you very much.
Old Apr 16, 2004 | 08:18 AM
Dave Henshall
thtas what i thought - all it costs is your time , and the car laid up for a day or so - and if they dont work its not a bog job to fit new ones anyway.
Old Apr 16, 2004 | 08:41 AM
Car has been laid up for three months while I build up the funds required to rebuild the head following a cam belt incident. Will be on axle stands for a while longer, so that gives me something to do in the mean time...
Old Apr 18, 2004 | 09:53 PM
Can anyone give me an answer to this question, I have had new tappets fitted a few weeks ago on a 2wd cos & before this was done my car didn't smoke at all & never really used any oil but i have noticed now it smokes a bit after giving it some as you come off overrun & put your foot back down & also going to the pod today has gone from full oil mark on dipstick to just above minimum (285 miles) where as before i had them fitted i went to the pod & went on the strip all day long came home & the oil level hadn't moved. As my knowledge on engines is limited can anyone tell me if just changing the tappets could make it use more oil if their not sealing or whatever as the old ones must have obviously worn in with the head. also since changing them it sounds like their is still a top end tappet noise coming from 1 of them & doesn't go away for a good 3 to 4 mins when cold.
Cheers Simon.
Rsmat
89
Oct 12, 2015 07:50 AM
gcfcos
59
Oct 6, 2015 05:04 PM
Adam-M
Was It You?
Oct 1, 2015 07:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
BigD.
Alloy wheels and ICE for sale
Sep 16, 2015 03:08 PM
