what oil filter
Old Dec 22, 2010 | 08:41 PM
burnhamshaun's Avatar
burnhamshaun
Default what oil filter
i have a 2.1 zvh what oil filter do i need also want to change the ht leads seen some magnacor ones one ebay does it matter what leads i get or are they all the same mines an efi if this helps
Old Dec 22, 2010 | 09:04 PM
tommytxr's Avatar
tommytxr
why o why do i do it!!!!!
what car is it in as you can use a few mate ive used a mann72/4 before
Old Dec 22, 2010 | 09:06 PM
burnhamshaun
escort cabriolet mk4 also any idea on the leads
dannymc86rscab's Avatar
dannymc86rscab
should be efl 600 mate the longer ones!
Old Dec 22, 2010 | 09:09 PM
dannymc86rscab
efl being the geniune part no from fords, and being cvh with efi set up im guessing not 100% but surely fiesta rs leads should be fine??
Old Dec 22, 2010 | 09:18 PM
burnhamshaun
what about these
http://cgi.ebay.co.uk/Escort-RS-Turb...item230ca6d1af
or these as mine are fine and work well but are tatty and one is split but i think mine are just standard ones the are black
http://cgi.ebay.co.uk/Escort-RS-Turb...item27b76f59fe
Old Dec 22, 2010 | 09:24 PM
dannymc86rscab
im guessing you have a coil instead of a dizzy?? im sure they are the dizzy ones, but someone else will confirm if they read and see them!! but as for standard probably although i think the fiesta standard were sometimes red!! but think you should look for 10mm leads as opposed to 8mm!
Old Dec 22, 2010 | 09:29 PM
burnhamshaun
these the ones i need then
http://cgi.ebay.co.uk/ESCORT-XR3i-FI...item5d2ca0421d
Old Dec 22, 2010 | 09:35 PM
dannymc86rscab
they look more like the ones best bet is have a quick look at your ones you have now, if they got the clip bits at the end that goes on to a coilpack then yeah, if you just have push on ones then its the dizzy ones so go for the ones you found first!
Old Dec 23, 2010 | 02:33 AM
tommytxr's Avatar
tommytxr
cant use that one if hes using the 2.0l oil pump, may get away with it if its got a 1.8l oil pump on as the efl 600 hits the lower front chassis leg
Old Dec 23, 2010 | 02:36 AM
tommytxr's Avatar
tommytxr
its a 2.1 zvh not a cvh so oil filter in a different place
Old Dec 23, 2010 | 04:43 PM
burnhamshaun
so which one do i need then guys and the leads in the last pics the ones i need as i need to get these ordered
Old Dec 23, 2010 | 04:45 PM
burnhamshaun
this one
http://cgi.ebay.co.uk/OIL-FILTER-For...item2eb0399951
Old Dec 24, 2010 | 05:43 AM
burnhamshaun
Is this the one ^^^^^^^^^^^^
Old Dec 24, 2010 | 02:47 PM
xrmalin's Avatar
xrmalin
I used a cvh oil filter on my zvh turbo engine as like its been mentioned earlier the zetec one is too long to fit between the engine and chassis leg. There both the same thread size between the zetec and cvh its just the cvh one is shorter.
mark.
Old Dec 24, 2010 | 03:15 PM
burnhamshaun
nice 1 thanks mate ill order one
tankybaby66
Feb 6, 2016 02:24 PM
Nov 1, 2015 06:53 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
Johnny Knoxville
Sep 30, 2015 07:21 AM
