What Is Needed For Stage 3?
Old Mar 25, 2004 | 08:42 AM
Nik_W's Avatar
Nik_W
Default What Is Needed For Stage 3?
After spending a year at stage 1, I have decided to take the next step and go to Stage 3. I have an Ahmed Bayjoo Stage 3 chip and I'm currently bidding on a brand new 3 bar map sensor and set of 803s. I only have standard T3 turbo and std intercooler at moment but hopefully around summer, I'll upgrade those 2. I'll be taking my Saph into Harvey Gibbs to have it set up with the above, but what sort of power can I expect? But what I really need to know is, do I need to upgrade anything else? I know I can't run too much boost with the standard T3, so will the head gasket be ok or does that have to be upgraded?
I'd appreciate any advice, cheers!
Old Mar 25, 2004 | 11:14 AM
PJay's Avatar
PJay
Grp A Head gasket is advised but i wouldn't worry too much
Old Mar 25, 2004 | 12:01 PM
Mike Gurney's Avatar
Mike Gurney
you should get 310 bhp at least
id suggest a 4x4 intercooler and a 4x4 turbo if your turbo fails
Old Mar 25, 2004 | 12:05 PM
Switch's Avatar
Switch
If ya dont win the auction then check out the for sale section cause i have a 3 bar and greens for sale
Old Mar 25, 2004 | 04:14 PM
Nik_W's Avatar
Nik_W
Cheers guys!
Old May 5, 2004 | 11:29 PM
kossykarl's Avatar
kossykarl
IF YOU ARE GOING OVER 300 BRAKE AN UPGRADED BREATHER IS A MUST DUE TO INCREASED CRANKCASE PRESSURE , OTHERWISE YOU MAY KEEP BUSTING SEALS AND GASKETS
CHEERS KARL
SmudgerByName
52
Jul 28, 2016 06:14 PM
biggiejody
Insurance
Sep 2, 2015 12:04 PM
JasonPD
21
Aug 20, 2015 07:36 PM
col93saphcos
Aug 7, 2015 03:21 PM
