Idle issue...
Old Jul 30, 2010 | 05:09 PM
K8yLouGTI's Avatar
K8yLouGTI
Some Kind Of Idiot
Unhappy Idle issue...
Have replaced the plugs and leads on my Escort GTI but it still has a slight missfire when at idle and the car seems to quiver yet when I drive off it dissapears? Also it tends to hunt quite a bit and also sometimes when I pull up to traffic lights or a junction the idle sticks at 1500 and dosnt drop for about 30 secs then when I drive it again it feels like its running away with me cos its idling high.. grrrr any ideas cos its driving me up the wall
Old Jul 30, 2010 | 06:11 PM
oldford's Avatar
oldford
High idle can be caused by an air leak. Check all hoses for cracks and leaks around the inlet manifold.
Old Jul 30, 2010 | 09:15 PM
left hooker's Avatar
left hooker
same prob on my focus a hose had a hole in it drawing in extra air causing lumpy idle/holding the rev's up and or stalling
or you have a gasket gone on your inlet manifold
Old Aug 1, 2010 | 01:46 AM
K8yLouGTI's Avatar
K8yLouGTI
Some Kind Of Idiot
Funny you should say that, there is a hissing noise coming from the engine somewhere! I will see what I can find
Thanks
Old Aug 1, 2010 | 08:22 AM
Also check the PCV valve, if these stick they let air in and cause what you have including the misfire, as if stuck open at idle(should be shut) they weaken the mixture, to a point where it can be too weak to ignite correctly, no correction is made for this as it is after the air flow metre.
Old Aug 1, 2010 | 08:49 AM
forevaford's Avatar
forevaford
a comon problem is the rubber breather pipe splitting underneeth the coilpack. it goes to the inlet manifold. dous the hissing sound underneeth the coil pack? best to remove coilpack to repair
Old Aug 1, 2010 | 10:13 AM
K8yLouGTI's Avatar
K8yLouGTI
Some Kind Of Idiot
Well I cant quite decide where its coming from, sometimes it sounds like its coming from down the back near the manifold and then other times it sounds like its coming from near the air filter lol
Old Aug 6, 2010 | 10:23 PM
woody1's Avatar
woody1
hi im having the same problem with my s2 turbz can any one help
fordrallycar
Sep 30, 2015 07:57 PM
Shaunc
Escort Range
Sep 23, 2015 06:00 AM
RSmark84
Sep 13, 2015 01:29 PM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
routemaster
Sep 7, 2015 05:27 PM
