ERST Brake Problem
Old Jul 8, 2010 | 11:09 PM
JamesyRS's Avatar
JamesyRS
Default ERST Brake Problem
Hey guys,
Driving car tonight then suddenly brake pedal was near floor before brakes worked, brakes stopped fine but pedal moved away down couple o pumps it was back to normal, this continued all way home, servo knackered? I did see some weeping from it so guessing this problem just want a second opinion thanks guys
Old Jul 10, 2010 | 07:14 PM
ECOS95's Avatar
ECOS95
Master cylinder could be cream crackered.
Old Jul 11, 2010 | 01:06 PM
JamesyRS's Avatar
JamesyRS
thanks for that mate, I went and bought new servo and master cylinder and u no what problem was? the hub bolt on drive shaft was 3 threads from coming off!! All sorted now thanks for the idea tho
Old Jul 11, 2010 | 02:38 PM
cabriolet's Avatar
cabriolet
seen this when wheel bearings collapse fella
Old Jul 11, 2010 | 05:22 PM
JamesyRS's Avatar
JamesyRS
wheel bearing fine mate problem was nut had come loose no1 had chapped the bit in to lock it in place so became loose
yatta
May 21, 2016 10:31 PM
focus2351
Sep 9, 2015 09:33 PM
routemaster
Sep 7, 2015 05:27 PM
cossirob
Sep 3, 2015 09:17 PM
