mondeo mk2 1999 help please
Old Jun 25, 2010 | 09:54 PM
dadscabs's Avatar
dadscabs
Default mondeo mk2 1999 help please
hi new on here need some advice brake fluid leaking from driver side rear wheel can anyone tell me what can cause this as i have no brakes thanks sorry i have a 2litre injection v reg mondeo hatch zetec
Old Jun 26, 2010 | 09:25 AM
martysmartie's Avatar
martysmartie
If it's drums at the rear then most likely the problem will be the wheel cylinder, if discs a leaking caliper or brake hose.
Martin
Old Jun 26, 2010 | 10:08 AM
steves24V's's Avatar
steves24V's
you sure its leaking from the wheel, the brake pipes around the fuel tank rot like anything, i fail so many on mot's and had a couple in that have rusted though and leaked.
Old Jun 26, 2010 | 01:51 PM
dadscabs's Avatar
dadscabs
thanks will check as soon as poss how do i go about fixing the problem if it is what your suggesting thanks once again regards paul
Old Jun 26, 2010 | 10:10 PM
dadscabs's Avatar
dadscabs
checked and its the rear drivers side brake hose but cant really get to it taken wheel off but its not easy to get at any ideas greatly appreciated cheers
Old Jun 27, 2010 | 10:56 AM
If I remember rightly it's the tank in the way ?, if so needs lowering, as said above dreadfull design bit this leading to problems later on.
wowk
Mar 30, 2021 07:49 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
Kiran1600E
11
Oct 2, 2015 11:35 AM
Sp3no
Sep 27, 2015 07:23 PM
Marv888
Sep 26, 2015 03:44 PM
